New bars no throtle response
Same here, can't remember the code it was spitting out but I had to rewire the entire TBW as I had pulled a solder loose feeding the wires through. Pain in the butt pulling it all back apart.....
Got it figured out guys with all the help. I was mocking it all up to gut the codes and it started and worked fine. Reassembled it with bars nothing. Turns out the green plug would lose contact just enough when pulled through the bars. Took it apart cleaned it applied some dielectric grease and taped it together. Good to go so far. Haven't got to ride as its raining here but started it numerous times through the re assembly process to be sure. Reason I had it apart was new bars and painting inner fairing and other black pieces the bike color. Will post a few pics when weather clears. Thanks again for the help and ride safe.
