Transmission/Clutch problems only when hot!!!
My 2014 ultra limited is not wanting to down shift out of 3 when I stop I have to up shift and re down shift it. The other day it started grinding when I tried to put it in first gear on the down shift. This problem only happens when I ride over 150miles at a time when the bike is cold it shifts like butter but when it gets hot watch out. I'm running Spectro 6 speed gear oil in the tranny because the Harley syn was crap. Has anyone else had this issue???? It has 3200 miles on the bike.
it's not the lube. Transmission lube has nothing to do with your problem. It's in primary. It's your clutch adjustment. Make sure you have a little freeplay at lever were it closes on mount. Do not back it totaly off. Now cold, set the backoff of the clutch behind the derby cover to the manual or speck on what clutch you are running. Be sure to crank it in past no play by a couple turns to smooth thread and lever it to insure you are starting at no free play when you do back of. Now lock it (not inch lb torque..not too tight..fine threads will not come loose.. I just bump mine with my palm) and then adjust lever free play to minimum spec with cable. Now do the clutch and look at the space of the clutch driven and drive disk and make sure you see then move apart. Your problem will be gone.
To you inquiry....I don't think any H-D will downshift to 1st from 3rd while stopped without playing with the clutch lever through each downshift. I would suggest finding 1st before coming to a complete stop.
Also, what is your basis for stating "Harley syn was crisp"? What was your experience?
If I have read your post correctly, other than in exceptional circumstances (such as a panic stop) you shouldn't be stopping in third gear. I've just got in from a day's ride and never failed to be in first or neutral (depending on traffic) by the time I was stationary. Having said that, it is worth visiting your service department and getting them to confirm that all is well with your clutch settings. If you plan on keeping your bike for a long while it is worth getting the service manual while you are there, then you can put us right on the correct procedure for adjusting the hydraulic clutch!
