Clutch adjustment or transmission issue
Old 07-27-2014 | 04:14 PM
jklisemtp's Avatar
jklisemtp
All Fixed, Just needed to do a proper clutch adjustment. Thanks
Old 07-27-2014 | 04:53 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Unadjust your cable 1st then adjust your clutch pack all when it's cold per the Manual for your bike you should be good to go!
Old 07-27-2014 | 05:57 PM
checkers's Avatar
checkers
Several things going on here. Adjust your clutch basket cold, after loosening your clutch cable. Go to How To videos on you tube, several video's on this adjustment. Also drain and change the primary fluid to a mineral oil such as Rotella T 15w40 or non synthetic primary specific fluid.
Old 07-27-2014 | 06:07 PM
SafetyMan's Avatar
SafetyMan
Or a specific Primary Fluid, like F+, Red Line synthetic primary or Drag Specialties Primary Fluid
Old 07-27-2014 | 07:01 PM
lp's Avatar
lp
Or just adjust the clutch - like he did four posts up when he solved the issue...
lp
Old 07-27-2014 | 07:07 PM
69cj's Avatar
69cj
Proper procedures do seem to alleviate certain problems. It seems that buddy's create more problems, some times, than they correct.
Dynadev
11-15-2016 10:21 AM
Toner123
02-28-2016 12:30 AM
EZRider76
04-29-2015 07:55 PM
502sport
03-13-2012 09:07 AM
HDCopper
04-07-2009 07:39 PM
Quick Reply: Clutch adjustment or transmission issue
