Clutch adjustment
07-13-2014, 03:23 PM
Clutch adjustment
I have adjusted and re-adjusted my clutch several times, I keep getting the little bit of clunk between the gears. I had my compensator replaced about a year ago. The mechanic adjusted it perfect. It shifted like butter. I can't seem to get that again. What am I doing wrong ? Thanks
07-13-2014, 04:09 PM
Adjust the cable length to a "thick nickel" of free play at the perch. Sounds like you're not getting completely disengaged.
Mark
07-13-2014, 04:23 PM
Are you talking about between the ferrule and the lever bracket ?
07-13-2014, 04:27 PM
Quote:
Originally Posted by
OU812
No, at the lever where it hinges. A thick nickel between the lever and the casting. The cable adjustment is on the down tube near the front cylinder.
07-13-2014, 04:40 PM
Its hard to read your post, your avatar is sooooo distracting
splashback
03-25-2019 09:53 AM
CGLTD
02-12-2014 04:00 PM
rufasim
04-13-2013 12:49 PM
MAX EVO
11-14-2007 03:31 PM
st john
04-03-2007 12:31 PM
