gotta fall away
Thanks, fabrik8r. I got the Ricors from you and have read your explanation elsewhere. I think that's what I've got going on, but I'm checking everything.
Brian at Ricor thinks the cause is too much preload. Mine is 39 mm. I have 1 kg RT springs. Brian thinks with those springs and my 210# weight, always solo, I should have only 25 mm of preload. All other resources (Rick @ CCE, RT, etc.) recommended 35-39 mm of preload.
Silvio
04-28-2015 03:24 PM
