high idle RPM
Old 07-11-2014, 06:00 AM
slammed05fatty's Avatar
slammed05fatty
slammed05fatty is offline
Default high idle RPM
stock and stage 1 idle stayed right around 1000
since having my cams installed my bike has had a higher idle, usually 1000-1200 RPM, this morning it never idled unde 1300-1400 and as high as almost 1600 everytime i stopped on my way to work this morning. not sure whats going on.
my friend had the same shop install the same cams in his 96'' and then used the same dyno guy and his idles @900-1000 RPM, our 2 bikes have a completely differnet idle lope sound. thats what first drew my attention
is this something the dyno guy has done or can fix? or can i adjust it w/ my power vision?
Old 07-11-2014, 06:08 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Scrmnvtwins is offline
Lean Air Fuel Ratio will run higher RPM under no load condition. Did youchange your Fuel map for the new cam?
Old 07-11-2014, 06:09 AM
slammed05fatty
it was dyno'ed and tuned for my current set up
Old 07-11-2014, 06:11 AM
Scrmnvtwins
OK I see you are asking about the Power Vision, I have experience only with USB3 and PCV but believe your power vision has the ability to be remapped for the leaner AFR with the new cam getting more air thru the system. If it were me and I was working on the maop I would add some fuel to the 0-2% and 750-1500 RPM zone to richen it up and slow it down.
Old 07-11-2014, 06:12 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Call the dyno shop and ask!
Old 07-11-2014, 06:14 AM
Scrmnvtwins
Mt Brown is right, If you paid for a map it should be right
Old 07-11-2014, 06:17 AM
slammed05fatty
i will call them but htey are closed today. wanted to get some insight to see if it is even something to bother them about.
lp's Avatar
lp
lp is offline
Received 2,853 Likes on 1,601 Posts
Idle speed is set by the ECM.
If you have a power vision there is a setting somewhere in there that allows you to adjust it.
If you find the setting is at 1000 RPM, you may have a bad Head temp sensor - so the ECM thinks the bike never warms up and runs a high idle.
You can verify the sensor readings in your power vision as well.
As mentioned before, probably best to take it back to your tuner if none of this simple stuff is the problem.
lp
Old 07-11-2014, 06:24 AM
Scrmnvtwins
Agreed tuner can set idle but if idle speed and AFR were not adjusted properly, this is an indication of lean AFR DYno tech did not get this 1 right
Old 07-11-2014, 06:34 AM
bbass's Avatar
bbass
bbass is offline
"Bother them"? You paid them to do the work and something isn't right, I would take it back to them and have them re-ajust the tune.
Quick Reply: high idle RPM
