high idle RPM
Old 07-11-2014, 09:01 AM
slammed05fatty's Avatar
slammed05fatty
slammed05fatty is offline
i did not try that. honestly didnt think anything about it. i'll try that before i leave work today to see if that helps, if not then when i get home i'll adjust it
Old 07-11-2014, 10:20 AM
Piggs's Avatar
Piggs
Piggs is offline
Originally Posted by shooter5074
This may be a dumb question, but, did you try doing a throttle reset yet? Ignition on, off, on, off, on, off.
Occam's razor...... All things being equal, the correct solution is usually the simplest.
"dumb question" i don't think so but i'll bite what is it supposed to do? "throttle reset", I know resets the throttle... but to what setting? stock rpm? that's to say it readjusts the ECM? I didnt know that.
Old 07-11-2014, 10:45 AM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
Sometimes, people unknowingly blip the throttle as they shut off the bike. The ECM remembers this and sets the idle to this higher setting. Cycling the ignition on, off, three times resets the idle to the original 1000 rpm range.
Old 07-11-2014, 11:42 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Weavr99FLHT is offline
I thought it was 4 times
Ignition off , run/stop set to run
Ignition on count 1,2,3
Ignition off count 1,2,3
Repeat 3 more times
I have local mechanic that ALWAYS reaches with his left hand to turn of ignition while right hand is on the throttle and I ALWAYS have to reset the idle afterwards ....
Old 07-11-2014, 11:48 AM
shooter5074
Repeat 3 more times
Sorry, it is 4 times. Wait for the security/engine lights to go out between cycles.
Old 07-11-2014, 12:30 PM
slammed05fatty
i doubt this will help me as i usually use my right hand to turn the bike off, but i cant speak for hte mech. or the dyno guy, so its worth a shot. i thought it was 3 times but i will do 4 just to be sure, extra cant hurt
Old 12-13-2014, 08:48 PM
Joe_G's Avatar
Joe_G
Joe_G is offline
Check and make sure your throttle shaft didn't crack and break at the screw on the left side when looking at it. That is somewhat common and when it am happens your throttle position sensor on the left side gets a faulty reading and you have a high idle.
Old 12-13-2014, 09:43 PM
lp's Avatar
lp
lp is offline
Received 2,853 Likes on 1,601 Posts
He had different throttle body (TBW) than the previous years with the setup you're mentioning and he no longer even has that bike...
Even still he never did come back and tell us all what the problem was. Kinda wondering.
Old 12-13-2014, 10:07 PM
Musician's Avatar
Musician
Musician is offline
2008 FLHT stage 1 plus some stuff. Had high (1500-1600) idle, and after messing with it and getting very frustrated, I remembered reading somewhere (Here, I think) about that reset trick. It worked. Have had to do it a couple times over the years, but it has worked every time.Thanks to all you folks out there sharing your experiences. Lots of good advice and tips.
Old 12-15-2014, 06:57 AM
slammed05fatty
i ended up using my power vision and adjusting the idle RPM down to where i wanted and never had anymore issues
Quick Reply: high idle RPM
