Lowering the front fender
Old 04-04-2007, 01:03 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
Default Lowering the front fender
I've decided on going with 18's both front and rear and wondered how you guys that have lowered or know someone that did lower their front fender to give it that "big wheel" look, how was it done?[sm=ummmmokay.gif] I've examined the setup on my bike and would like some input.
Dremmel the holes........whaaaaaaaaaat?
Old 04-04-2007, 01:19 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Default RE: Lowering the front fender
I did it with brackets from http://www.nativecustombaggers.com/products.php
Rick
[IMG]local://upfiles/24067/163F7124ADD8434DA3B5DACC24E8910A.jpg[/IMG]
Old 04-04-2007, 01:23 PM
UltraKla$$ic
ORIGINAL: Egldr05
Rick
You welded the bracketsin? If so, did you have to repaint the front fender?
Old 04-04-2007, 01:26 PM
Fast Eddie's Avatar
Fast Eddie
Fast Eddie is offline
I got mine from Native also. I just ordered the entire fender pre assembled rather than just the brackets. One piece of advice whether you order the complete fender or just the brackets: be sure to seal the joint (I used a marine sealant) where the bracket meets the fender on the inside to prevent water from collecting between the bracket and fender and causing rust.
Old 04-04-2007, 02:34 PM
torquet's Avatar
torquet
torquet is offline
I also used the native custom brackets but I just ground down the rivets from the inside, becareful not to get them to hot. Then clamped the fend to the brackets on the bike, marked the holes, drilled them and used chrome allen screws with blue locktite and bolted the on. Looks good. If I had the extra money to have thempainted I would have welded them on but the chrome allen screws dont look that bad.
Old 04-04-2007, 02:44 PM
04harleyboy's Avatar
04harleyboy
04harleyboy is offline
I have a set of native custom brackets that I did not use, if you are interested, I will sell them at half price plus shipping. PMme if you are interested in them.
Old 04-04-2007, 02:45 PM
UltraKla$$ic
Gonna have to reexamine how my current setup is on the bike in order to get a better mental picture of this fab. If I had a template, I'd just make the current holes a little bigger in the correct position, but with my luck, I'd go the wrong direction with the holes and booger something up. The "direction" I'm referring to in reference to modifying the current holes is up and forward in order to bring the fender down and back...........I guess.[&:]
Old 04-04-2007, 02:46 PM
UltraKla$$ic
ORIGINAL: 04harleyboy
Rob, did you move your fender at all?
Old 04-04-2007, 05:08 PM
Eglider05's Avatar
Eglider05
Eglider05 is offline
2nd Gear
[/quote]
[/quote]
Yes, the brackets are welded from the back side and the fender was repainted. Doing it this way allowed me to get rid of the rivets.
Rick
Old 04-04-2007, 06:51 PM
Hollywood's Avatar
Hollywood
Hollywood is offline
I ordered one of these for a 16' wheel from Russ Wernimont.
http://www.russwernimont.com/pics/gallery/HIX2.jpg
Quick Reply: Lowering the front fender
