120r in my 2014 flhxs causing chain tension issues
Old 07-09-2014 | 08:44 PM
SavageChopper's Avatar
SavageChopper
I had the Hayden and didn't like how tight the chain was. I also had hard starting and a compensator knock while starting and shutting off. I installed the Baker manual adjuster with 3/4 inch of chain flex and all my issues went away. I checked the shoe after 1000 miles and there was no wear.
Old 07-09-2014 | 11:17 PM
Bobo2011SG's Avatar
Bobo2011SG
I'll let you all know how it works out. It should be here tomorrow.
Old 07-10-2014 | 03:12 PM
GARYR's Avatar
GARYR
I use the Baker chain adjuster with my R&R 124 and it's perfect.
Old 07-16-2014 | 11:46 PM
Bobo2011SG's Avatar
Bobo2011SG
The noise I heard when the chain got over tight with the stock adjuster was loud. The Hayden is tight, but not as tight as the stock adjuster got on me. Noise from the case with Hayden installed is audible, but not as bad as the over tight stock adjuster. Hayden says give it 500 miles to wear in. I'm gonna do that and report back. So far it's better.
Old 07-17-2014 | 01:27 AM
103 sedona orange's Avatar
103 sedona orange
Baker!!!!
Old 07-17-2014 | 05:36 AM
sporacer's Avatar
sporacer
I never had an issue with my auto adjuster. If your concerned the baker manual adjuster is the best choice.
Old 07-17-2014 | 11:14 AM
JohnCA58's Avatar
JohnCA58
A few of the guys with big H.P. are taking the OEM adjuster and setting the chain at 5/8 play and welding the wedges in place. working well and if needed to readjust, grind welds off and reweld in position needed.
Old 07-17-2014 | 11:55 AM
hog95023's Avatar
hog95023
I don't have big HP but saved my stock tensioner in case I have an issue with the baker I'm running and will do just that. Actually may try and bribe you to do it.
Old 04-10-2015 | 11:06 AM
Bobo2011SG's Avatar
Bobo2011SG
I don't like the chain slap and noise from the tension of the Hayden. Just ordered a baker unit. Should be installed next week.
Old 04-10-2015 | 11:39 AM
GPHDXLC's Avatar
GPHDXLC
Originally Posted by vickers1
My Hayden wore half through in 6 months. Don't know why. Got the HD one back in now.
Same with me and Hayden was of no help for me as for customer service. I have a Thread on here that has pics of it, do a Search.
Quick Reply: 120r in my 2014 flhxs causing chain tension issues
