Totally stunning! I'm was impressed with the before look but the after look is evencooler.
BTW... great idea with the rear wheel. Just curious was it cheaper or more expensive than the front? Because if it was cheaper that pure genius.
Again, love the look - that is a Killer King you have there.
Thanks. Not cheaper. It would havecost about the same if I went with the Blade wheel on the rear although I suspect you could find a cheaper solid rear wheel than the Weld Eclipse. However, it's worth it to me if I spend less time cleaning the rear wheel and more time riding.
Very, Very Nice. What are you using for the rear shocks?
Thanks. The rear shocks are the Legend Air Ride System. They are connected to lowering blocks which I will probably remove as there is a clearance issue with the rear fully lowered with the 18" wheel / Metzler tire combination that I did not have with the 16" wheel / Dunlop tire combination.
