Detachable Tour pak Lock...useless???
Old 07-07-2014 | 01:51 PM
craigffb's Avatar
craigffb
Originally Posted by Streetrunner
In your pic in your above post, if the back of the tour pak is towards the left you have the latch on backwards. The key mechanism should face you ax you are locking at the rear of the bike. This will provide easy access to lock and unlock.
Once that one screw is removed the latch becomes severed from the bracket. It's that simple.
He has it on right. Once the screw is removed the lock is still locked around the docking point. No way to get it off unless you take the screw out of the docking point and remove it. You know the latch is on a threaded pin right? It's not just gonna flop around with the screw out. Did you take one off/on yet?
Old 07-07-2014 | 02:03 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Mine broke after removing the tourpak 3 or 4 times. Useless waste of money.
Old 07-07-2014 | 02:51 PM
Streetrunner's Avatar
Streetrunner
I don't have a pin holding the latch on just the screw and once the screw is removed the bracket of the tour pack will just slide away because the latch is no longer attached to the tour pak it is just hanging around the docking point.
Old 07-07-2014 | 03:15 PM
craigffb's Avatar
craigffb
Is it an aftermarket rack?
Old 07-07-2014 | 04:29 PM
Streetrunner
Its a HD quick detach kit that also provides antennae relocation hardware.
Old 07-07-2014 | 04:48 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by 2002flstc
Even the best lock is only to keep an honest person honest...
gee, and I thought it was honesty that kept an honest person honest... seriously... you can leave a wallet full of cash on the seat of the bike and an honest won't take it... why? not because of any locks.... because he's honest.
Old 07-07-2014 | 05:38 PM
craigffb's Avatar
craigffb
Look at part #3 in the PDF for just the detachable rack. These are the pivot pins that keep the locks from flopping around without the screw. If you don't have these there is a problem with the rack.
http://www.harley-davidson.com/en_US...ts/-J04756.pdf
Old 07-07-2014 | 06:21 PM
2002flstc's Avatar
2002flstc
You seem to have missed the point... while a lock is useless against an honest person as it is not needed because he/she is honest... it is equally ineffective against a criminal... it may slow them down a bit but it will not stop them.
Old 07-07-2014 | 06:35 PM
Milwaukeebuddy's Avatar
Milwaukeebuddy
The touring model latch is completely exposed whereas on the Heritage Softail, the latch is blocked from view (and wrenches) by the saddlebag. So apparently this locking latch works better on some models.
But the quick grab and go would be eliminated..
Old 07-07-2014 | 07:12 PM
lkr0's Avatar
lkr0
same thing happened to me -- not worth the money
Originally Posted by Av8rPaul
I went to unlock mine the other day and with not much effort at all busted the little pin off, spring shot out, felt stupid. Pretty much in that order.
Quick Reply: Detachable Tour pak Lock...useless???
