tranny oil?
Actually oil is less dense then water, but heavier than water. So are you saying water can leak thru a gap smaller then oil can leak out of? I know the oil companies say one of the main reason oil has a shelf life is moisture can get into a sealed plastic bottle. jmn1960, have you still got the milk oil? Put it in a sealed jar and let it sit and see if water shows up on the bottom. Your're using a GL5 oil that has a lot of additives. Know this is not an oil thread but the call out is GL4 since your shift forks have bronze on them.
thanks
Here is a link. Best of my knowledge from reading what the makers say, I just try to quote what they say and not what someone says that it work for. Interesting that you say your Valvoline is GL4. I have a container that says GL5 and we used it in a limited slip rear end in a Mustang.
https://www.hdforums.com/forum/sport...-answered.html
GL4-GL5 no biggie, the GL5 has a slightly better additive package. Might help, won't hurt. Do you wash your bike when it's still hot? If you do, the tranny can create a vacuum when it is suddenly cooled by the wash water and actually suck water into it. Stranger things have happened, so don't be alarmed. I never wash a hot bike.
it said that it was both GL4 & GL5 compatable and yes limited slip also
and no I never wash the bike hot
oh well I guess it will me a mystery why the oil came out like milk,,it has got me puzzled but not gonna loose any sleep over it ,, just though it might have been the brand of oil and someone got the same reaction , but I guess not h\oh well
