Looks like I have a leaky fork on my 04 RK which means if I am tearing into it to fix it I will be installing the Progressive Suspension fork cartridge! I can't wait to see and feel the difference.
I thought I had a leaking fork seal but it was actually steering head grease that was running down to the top of the forks and wind blew it around a bit on other parts. Unless you are certain it is the fork seal you might want to check for this as it is common.
