Oil pressure
Cuz I'm sure every one who has air cooled bikes that ride in stop and go traffic for any length of time in 110 deg Arizona heat or similar change their oil and battery every time!!! Oh and their lights.
I think I'll use the black tape. I did finally find an old threat from 09 that talked about the Zero reading. Sounds normal for these bikes it seems.
FYI, the oil pressure light sensor is set at 4 psi, the light looks like its on zero when hot but if the oil light is not on youre ok. Does the oil light come on when you turn the ignition on before starting the engine? Thats a self test when it lights up like that, if its not coming on you have another issue.
Some of the auto mfr's fixed the problem years ago with owners freaking out when they saw low oil pressure readings on their gages when hot and idling. They redesigned the gages so they would read mid-range regardless of the actual pressure as long as there was minimal oil pressure. Happy customers now!!!!!!!!!! Of course they have no clue what their actual oil pressure is but hey, they quit complaining. Harley could go that route.
Yea I did the same thing as you and many others... only I looked after I did a oil change... yea I freaked out too and asked wtf
Arizona
03-04-2007 03:28 PM
