Removing brake rotors
Reading other threads on this I've learned a few things:
1. Get a Snap-on T-40 socket
2. Use heat
3. Penetrating oil
4. Replace the bolts
I'm pretty unclear on the heating part. New rotors are going on, so I'm not worried about hurting them, so do I just hold a torch on the bolt head for a while? Do I let it cool before attempting to apply the pressure? Should I perhaps drill a pilot hole in each bolt first?
Or am I better off getting a real shop to remove them?
Michael
2. Use heat
3. Penetrating oil
Michael
heat to break the lock tight , heat the bolt head , hot but you don't have to get it red hot, should come out fairly easily when the loctite melts. would. I think an impact gun might help vs a breaker bar , but that more of an opinion, apply the heat and try tp loosen the bolt it if it doesn't break loose try a little more heat before using enough force to round out bolts.
