Down shifing teqnique
Old 06-27-2014, 03:56 AM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
Default Down shifing teqnique
When you down shift from say 4th to 1st do you pull the clutch in and down shift without letting the clutch out with each click of the shift lever until you come to a stop or do you let the clutch out after each down shift to let the engine help slow you down. Im curious if different techniques put more stress on the primary.
Old 06-27-2014, 04:01 AM
MontyCop05's Avatar
MontyCop05
MontyCop05 is offline
I've always used engine breaking as much as possible as long as I've been riding anything. From dirt bikes and atvs when I was a kid to road bikes as a adult. Saves from heavy wear on the brakes and less frequent pad changes. Never had an issue engine wise do to the practice. I've actually had friends I ride with ask why they hardly ever see my brake lights. Since then I try to touch the lever enough to illuminate for the visibility but I stay off the brakes until I need to.
SG-Jay's Avatar
SG-Jay
SG-Jay is offline
I always downshift blipping the throttle, letting the clutch out allowing the engine to assist in braking.
Old 06-27-2014, 04:19 AM
Hogi's Avatar
Hogi
Hogi is offline
I Do most of braking by engine breaking in 40 years!
Old 06-27-2014, 04:35 AM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,548 Likes on 6,277 Posts
Depends. If I have a long coast up to a red light, I'll hold the clutch in and downshift, so if I do have to accelerate, I'll be in the right gear.
Old 06-27-2014, 04:38 AM
Ron750's Avatar
Ron750
Ron750 is offline
Depends. If I have a long coast up to a red light, I'll hold the clutch in and downshift, so if I do have to accelerate, I'll be in the right gear. If I am in traffic, I downshift, while blipping, to even revs with gears.
Old 06-27-2014, 05:55 AM
larsfum's Avatar
larsfum
larsfum is offline
I downshift by blipping the throttle as well, letting the clutch out. Just make sure that you are low enough in rpm's when you do.
Old 06-27-2014, 05:58 AM
Vincewd's Avatar
Vincewd
Vincewd is offline
I also used the downshifting to help brake.
Old 06-27-2014, 06:15 AM
Ron750's Avatar
Ron750
Ron750 is offline
Old 06-27-2014, 06:36 AM
cass's Avatar
cass
cass is offline
i've driven manual transmissions all my life. in all my vehicles i downshift down through the gears, seldom coast and go from a higher gear straight to 1st....might if i coast but thats seldom. i just had my front brake on the bike replaced at my 20000 mile service, i probably could have gone a little longer.....the back looked new according to the service folks. as mentioned on earlier earlier posts, make sure your road speed is appropriate to the gear you're gonna go in.....can be a little surprising if you're not.
Quick Reply: Down shifing teqnique
