HD Curved Licence Plate Holder Size?
Part #67900008 I want to install on my '13 SG. None in stock at the 2 dealers close by to check. If I order it they won't let me return it. My Ontario, Canada plate is 71/4" X 41/4". In the P&A catalogue all the other plate frames read fits up to 71/4" X 41/4". The description for the curved plate frame has no plate size mentioned. Could one of you guys with this curved frame give me a rough measurement? It would be much appreciated. Thanks!
http://accessories.harley-davidson.c...-frame-touring
Mine measures 7.25 x 4.25 from edge to edge measured on the outside cover. Measure taken from center of mounting screw to mounting screw is 5.75 x 2.75. Plate will need to be curved some to form fit. I also had to drill out a bit of one of the plate holes to get it to fit but no big deal.
The HD curved plate holder is the same as this Kuryakyn part. If you have an Indy nearby or if your HD dealer stocks Kury parts, check that one out.
For my plate, I had to trim up the corners and elongate the holes to line the plate up so all the digits would be readable; NY apparently likes to run their numbers/letters out to the very edge of the plate, and we also have our Registration sticker to add on to the plate. And yes, my part is the Kuryakyn version.
