Broken lower fairing vent
Noticed yesterday that the sliding vent thingy on my right side lower fairing was broken. The plastic had broken around where the mounting bolt goes through it.
I took it all apart and JB Welded it, hope it holds.
Is this something others have seen? I can't say I've seen threads on it but it seems to be a pretty flimsy design.
Know this is an ancient thread, but in case anyone else continues to have this issue with the older bikes; Harley has discontinued production of Part# 58889-05 (Right vent door) and it is no longer available. The left vent door, Part# 58890-05, is also obsolete but is still available on ebay. Go figure that Harley would do that, I am unsure if the after market vent doors are exact replacements or if the aftermarket sellers will sell just the replacement door. Have considered having a local fabricator make me replacements from polished aluminum but figured that it would be cheaper to just buy new aftermarket fairings. The ABS cement works well depending on the break.
Nope. Used ABS cement from the hardware store to repair it. Have started removing them during the summer months when they stay open to reduce me kicking it and causing damage. Use the black ABS cement and you won’t be able to tell it was repaired depending on the amount of damage.
