What's the smartest way to go?
Old 06-23-2014 | 09:44 PM
ridedaddy's Avatar
ridedaddy
Default What's the smartest way to go?
I'm looking to do a few upgrades to my 13 sg. Currently running a set of Cfr's with a decatted header and a set of vieds. I was wanting to change my stock ac and was thinking of maybe doing a ventilator or extreme ventilator. I was concidering a heavy breather but I may want to add lower fairings in the future for stereo purposes. The main question I have is other than the air cleaner I was wanting to add either a set of headers or a power vision? I don't have the coin for both. I'm kinda thinking I should go with the power vision before the headers for tuning purposes but wasn't sure if the vieds would get me by? I was debating between the v&h power duals, dresser duals, or the s&s power tuned true duals. I would kinda rather get the ac and the header but I'm thinking the tuner may be needed if I'm going to change the header so I should do the tuner first? Thanks
Old 06-23-2014 | 09:51 PM
LA VIC's Avatar
LA VIC
Well IMHO your current exhaust setup is good. The money you'd spend on a header and any of the systems you've listed won't give you much for the investment. Open up the intake and get a tuner.
Old 06-23-2014 | 10:05 PM
0ldhippie's Avatar
0ldhippie
Get a Power vision and proper tune!
Old 06-23-2014 | 11:36 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I think you're on the right path in getting a Power Vision Package first.
The ViED's will certainly help, and be sufficient for your exhaust and new A/C, but it sounds like you want to get the most you can power-wise out of the bike, thus my thought on the PV first.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 06-23-2014 | 11:49 PM
ridedaddy's Avatar
ridedaddy
I do plan to do motor work in the future so the tuner will be a must at some point. Maybe now is the right time. With that said will a header make having a tuner a must?
Old 06-24-2014 | 11:08 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
No, not a must at all. The ViED's will work just as well with an aftermarket header as with the stock headers.
Old 06-24-2014 | 11:34 AM
slammed05fatty's Avatar
slammed05fatty
X2
FYI u can run the heavy brather w/ lowers if u buy the short version
Old 06-24-2014 | 02:53 PM
LA VIC's Avatar
LA VIC
I'm not convinced a header is any better than your gutted setup unless you'd go big inches and cam. Spend your money elsewhere.
Old 06-24-2014 | 06:44 PM
ridedaddy's Avatar
ridedaddy
Hey slammed fatty your in my erea do you have any recommendations on a good tuner? I've heard the guy over at the rats hole in Decatur is good, the is another guy at a place called Steve's bike shop but I don't know much about him.
Old 06-24-2014 | 07:13 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
With a Power Vision you will get a tune with it that is customized to your bikes set-up. It also comes with auto-tune basic so that you do not need to spend time or money putting it on the dyno.
Read more details on all that you get with it HERE.
Quick Reply: What's the smartest way to go?
