Questions about setting sag on my new Ohlins shocks
Sag is set with the spring preload adjustment. Half turn means half a revolution.
Damping is set with the dial on the bottoms of the shock. This is adjusted by clicks, not by half revolutions or half turns.
More info than you asked for, but hopefully your question is answered?
I installed my #3-#3's last week.You should have received instructions with your invoice. On those, Howard says to call him when you install them. Yes, one-full revolution = 1 turn.
Setting sag on my Ohlins
This may not be the best way by any stretch but I set my sag using a PVC Pipe setup. As you can see, the "T" fits snug on the lower shock mount and with the bike on a jack stand with the rear tire off the ground I use two zip ties to secure a point of reference on the upper shock mount I then place a zip tie around the PVC even with the one on the upper mounting screw. Then I put another zip tie one inch lower on the PVC from the top zip tie and lower the bike to the ground and after sitting on the bike, if setting for one up riding, I adjust on the preload collar till the zip tie affixed to the upper shock support is even with the zip tie at the bottom, the one one inch lower than the top zip tie on the PVC pipe. Adjust each shock equally to achieve desired result. You can now fine tune your damping... Ride safe!
lyork (04-19-2022)
I cannot think of another product that receives such focused fanaticism as Ohlin shocks, especially if they are from Howard. It is truly amazing, and entertaining, seeing the convulsions people will go through on the installation, setup and adjustment of these shocks. I bet the engineering of the space shuttle pales in comparison.
Would you agree this would also accomplish the same task?
I'm probably 700-800 miles in so the shocks should be broken in. Ride quality is great, and I'm done with the tweaking. Now what to do about the front end...
