1157 LED Bulb
Autozone..about $17 for a two pack...What I run on my fender brake/run light. They will not work as a signal with out a load resistor but do fit. Seems to help my brake light switches last longer since I run the diode pack for the brake lights 3 bulbs. http://www.autozone.com/autozone/par..._887542_20312_
Here's what I'm using up front...
And the rear...
I have them paired with smoked lenses and they look great.
Also, no load equalizer is needed on the 14's
Amazon.com: Custom Dynamics Dynamic Ringz LED Turn Signal Inserts - Bullet style GEN200-AW-1157: Automotive
And the rear...
Received 8,297 Likes
I know you want the bulb, but I have Custom Dynamics lamps in front and rear lamps. this is on 13 Street Glide....bullet housings. also had to use the load equalizer. but for the money, I truly believe these are the best thing going. The lights are bright and work well....this is second bike I've had these on and I would not go without.
I would bite the bullet and spend the money on this set up and be done with it.
