Another stupid 1k service question
I just got my RK and 1k service coming up. My question is ,should I take it to the dealer($380), or should I do it myself? I looked at the videos and I think it's not that hard to change all 3 oils and the filter. I just wonder if they do anything more ,then changing fluids and the visual inspection. I'm planning doing as much as I can to save some $$$. Thanks for the feedback.
The 1k service is more than just changing your oil. Whether hd does more than that is debatable. You can find service check lists online, I reccomened getting the service manual and doing it yourself. The money you save would buy the manual and a jack. Keep your receipts for warranty purposes
That's awfully pricey, even if they are using synthetics. You can absolutely do it yourself. But there is more to it. You also need to do things like check the belt tension. Get a manual to make sure you feel comfortable doing it and also to make sure you have the tools you need. For any maintenance you do, save your receipts like others said.
http://www.kutterharleyonline.com/ha...anual-99483-14
I did the fluids myself and the dealer did the rest. It was under $100 to do it this way and I had it on record that they did the service. They did charge me for another primary gasket because they pulled the cover again for the clutch adjustment. I can do it and have the service manual but I wanted it documented that they did it for any warranty issues. Bike is out of warranty now so it doesn't matter.
I am doing the hybrid approach myself. While I have the service manual and am mechanically inclined, this is my first Harley and I prefer to have someone who (hopefully) knows what to look for a bit more than me check all of the things outside of the oils. I changed the motor, trans, and primary oil and they are going to do the rest for $150.
