Brake light switch
I think this is what you're looking for. I copied the pertinent sections from the installation instructions for my iso-grips.
"Roll or slide the rubber cable adjustment covers back so the adjusters are exposed. Make a reference mark on each section of exposed threads, or at least make a mental note of how much thread is exposed on each adjuster This will be helpful when you re-adjust the cables. Using your 3/8" and 10mm open-end wrench loosen the lock nut on the adjuster and collapse it (shorten the cable housing) as far as you can- this provides maximum cable slack.
See PIC2. Rotate the cable so it points directly away from the throttle sleeve and slide the cables out of the sleeve. (Careful, don't lose the small brass ferrules on the cable ends - they're not attached.)"
Those ferrules are very easily launched into oblivion.
Like mkguitar mentioned, a shim like the female end of a nylon tie wrap placed between the brake lever and housing prior to disassembling would save the switch (for future reference).
Whiffleboy
07-13-2007 11:49 PM
