No start click buzz no lights
My 2011 FLHP will not start. It clicks, makes a humming or buzzing noise and the lights go out. I have to turn off the ignition and turn it back on to retry. The lights are bright before I try to start it. The battery cables are tight and clean. Battery checks 12.8 volts but goes way way down when I hit the starter as if something is drawing a lot of juice. Ran jumper cables from my car battery and same thing no start. Ideas? If this was my old Evo I'd start with the solenoid but the lights going out seem strange to me. I'm not at all electrically talented so I'm thinking of getting it towed into a dealer. frustrated with this bike. My old Evo has been more reliable. Compensator, lifters, wheel bearings....and now another problem?
so the click is the solenoid closing- the humming or I would call a whining- is the starter windings burning up.
let go the button!!
you have low voltage.
charge you battery with a charger ( not tender) and test at autozone etc.
and check the cables
jumping it can blow your charging system if the battery is duff
mike
let go the button!!
mike
It's putting out about 14.2 volts when running so yes it's charging. Thanks!
I do wonder why it failed so suddenly. Never a hard start, never a slow crank or dim lights. Maybe a battery tender is in order. I always use one on the old Evo, but those charging systems were not as good as today's bikes.
John LaRoe
Shovelhead
09-15-2016 12:55 PM
