14 sgs head light fit 13 sg?
I think, and I'm going by my 2011 SG, that the Dual Halogen headlight kit requires a new mount ring that is different from the stock ring on the SG. At least, when I got the Dual Halogen kit, it came with a new mounting ring, so I had to remove the factory mounting ring for some reason...never tried installing the Dual Halogen WITHOUT the kit's included mounting. Since it's been a while since I did the swap, I can't tell you the differences between factory and the DH kit. Also, the wiring harness to connect the two bulbs was included in the kit; that may also be very different on the '14s.
Worst comes to worse, you give it a try. There may be something about the ring of the Dual Halogens that doesn't line up right with the factory H4 light's mounting ring, but it's not a very involved task to remove the stock headlight and try to mount your Dual Halogen in there.
