SG Light Bar on EGC questions
My bike's a 13 EGC and has an 09 EG Standard light bar with the license plate light on bottom. Works great but came across a great deal on a new take off SG light bar with integrated run/turn/brake so bought it. With the EGS bar I use a HD run/turn/brake module and am wondering if I still need to use that module or remove it with the new SG light bar. Does SG light bar just plug in and no need for module? Just don't want to fry anything.
Thanks for any info.
The '09 SG light bar is pretty much plug & play except for tag light but you can wire it across plug in tailight for your bottom fender light. On '10 up SG the wiring harness originates plugs into the bottom fender Tri-bar light. So unless you have that it would definitely require some cutting and splicing into your existing harness.
If it's '10 up SG light bar you wouldn't need rtb adapter. On '10 up the light bar actually plugs into bottom SG tri bar module. From SG tri bar light module a wiring harness exist it to connect to light harness under seat. This is why I'd said you have to do some wire splicing since you don't have SG tri bar. It'd be a plug n play deal if you could find 09 light bar though. I had both a 09 SG light bar & a '10 SG complete fender on my bike before going with current setup.
