Check engine light on, No Speedo or Tach
Took a short ride today and on the way home I notice that the turn signals were not shutting off after I made a turn. Then I notice that I had a check engine light on and the speedometer and tachometer were reading zero. The bike seemed to be running fine. I just had my radio replaced under warranty 2 days ago (30 miles) so the dealer was in the front fairing. I just the bike off and turned it back on in the garage and all seems normal. I haven't taken it for another ride yet though.
Any thoughts or ideas?
2006 ULTRA CLASSIC SE
My 2006 dyna does that once in a while. No idea why, but seems to run fine while happening.
If I turn the ignition off and then back on, all is fine again.
Last time this subject popped up in a thread, a couple of others said the same thing. I don't have any additional insight, but it seems to be an annoying intermittent glitch rather than an issue.
I had the same issue on my old RK, bad speed sensor. Didn't have a tach...so not sure if they work if the sensor goes.
Turbo Turtle
07-24-2012 03:31 PM
