DK Premium Breather Kit install with pics
Old 08-18-2014, 03:18 PM
aces25's Avatar
aces25
aces25 is offline
Originally Posted by fwb35
This is what I did, breather was $10, I had the hose in my garage.
Parts list? I like this setup.
Old 08-18-2014, 04:29 PM
nemick's Avatar
nemick
nemick is offline
Do you get any drippage from that? God, that sounds bad, lol
Old 08-18-2014, 04:57 PM
hardheaded's Avatar
hardheaded
hardheaded is online now
Received 2,633 Likes on 1,628 Posts
Originally Posted by EasTexUltra12
Unless I badly misunderstand you you want to run a drain from the stock airbox to the ground? Why? The whole point of the DK kit is to keep the nasty oil fumes from getting sucked into your intake at all.
David
no, i would like to route the breather system to the outside of the air box and to the ground.
Old 08-18-2014, 05:03 PM
MyFirstHD's Avatar
MyFirstHD
MyFirstHD is offline
I ran the breather line to just under the frame. I got the DK round breather kit with vented bolts but when the bike got hot you could smell oil and the vented bolts felt wet. Ordered the kit to run a breather line and bought some black gas line from the auto store. Been a couple years and I like it. Don't forget the Locktite.
Alan
Old 08-18-2014, 08:57 PM
Stang951's Avatar
Stang951
Stang951 is offline
Hey Eastec, (or anyone that can answer with a FM AC). Why cant you block the holes in the intake, use the factory rubber and runs that with a t under the bike.
Got me thinking about doing this mod.
Old 10-06-2017, 07:38 PM
guapodog's Avatar
guapodog
guapodog is offline
6th Gear
Originally Posted by DK Custom
Call or email the shop on Monday and Dawn or Natalie can make that happen for you.
Kevin, do you happen to know the size of the allen key for the stealth breather set up? The bolts are banjo bolts with the metal tubes pointing back toward the pistons. It might be an 8mm but don't want to force it in and scratch the black finish! Thanks.
Update! I did read the supplied instructions but found the online instructions recommend an 8 mm! I may have been reading the wrong supplied instructions due to ordering multiple items (complete air cleaner kit with stealth breather set up?
Old 10-06-2017, 08:30 PM
harkon's Avatar
harkon
harkon is offline
I bought the DK kit with the catch can. Both tubes run around the air filter and the T to the catch can. Nice and clean. I run a Kury Ally Cat air cleaner and just plugged the breather holes with pop rivets.
The bike pings less when it's hot out and runs like a top. And no more drips from the air cleaner. I love this setup and it was worth every penny! I highly recommend it! That and DK really is a class act.
Old 10-08-2017, 04:18 PM
paco12's Avatar
paco12
paco12 is offline
Default Breather
On my road king I bought rubber pugs at Home Depot that fit into the mounting hole were the fitting is and just drilled a 7/16 hole through the plug and put it on the fitting and ran two lines,NO T's used at all and run into atmosphere,a lot of condensation comes out glad I did mine
Old 10-08-2017, 04:19 PM
paco12's Avatar
paco12
paco12 is offline
Default Posting pics
How do I post a pic of a mod I did
sarge-glide
Oil Archive (no new posts)
04-20-2020 12:18 PM
CJeep
2014-2023 Touring Models
23
02-15-2019 01:30 PM
lrcormier
07-18-2017 12:18 PM
CVORoadKing2013
12-27-2014 11:27 PM
sully78
03-21-2007 02:25 PM
Quick Reply: DK Premium Breather Kit install with pics
