Adding Liquid Cool to 2013 and older
Old 06-07-2014 | 08:10 AM
madmustang4's Avatar
madmustang4
As a point of reference, the 110 upgrade kit for wet head 103's (PN 92500020) is $2,000. Includes pistons, 255 cam, heads, gaskets, etc.
Old 06-07-2014 | 08:27 AM
heavymetalthunder's Avatar
heavymetalthunder
It could be done but not as seamless as the new bikes. You'd have to figure out a way to mount the pump. Forget a 2014 ECM to control it, its a totally different bus system. You might be able to run the fans and pump off a oil temp switch or something. The 2 wiring systems are not compatible. The can-bus system of the 2014 bikes makes it impractical to upgrade a older bike. Trade up or seek other solutions like oil coolers or fans for the heads are my opinion.
Old 06-07-2014 | 08:28 AM
hardheaded's Avatar
hardheaded
i think the wet heads have a higher compression ratio and would run hotter without the water cooling. i think i like air cooled more and more.
Old 06-07-2014 | 09:23 AM
FX4's Avatar
FX4
Wow man you make this sound so complicated. I'm pretty sure all that would be needed is a thermostatically controlled switch to turn everything on. Kind of the same way guys used to like to do when building hotrods and wanted to get away from power robbing mechanical fans to cool the radiator.
Old 06-07-2014 | 09:34 AM
vickers1's Avatar
vickers1
There are a lot better ways to throw away money on your bike but it is your money. Of the 5 Harley's I've owned, approx. 0 of them needed this mod.
Old 06-07-2014 | 10:18 AM
dribble's Avatar
dribble
Originally Posted by bundy43
I just can not see that being the case for very long,I still think the heads will crack over a long period of time.
Yeah in about five minutes with empty water jackets.
Old 06-07-2014 | 10:30 AM
petom's Avatar
petom
It would be more practical to always ride in the rain.
Old 06-07-2014 | 10:33 AM
Smittyjf's Avatar
Smittyjf
That's the main reason right there.
Old 06-07-2014 | 10:51 AM
FX4's Avatar
FX4
My money says sooner or later there is an upgrade kit available whether from the MotorCo or aftermarket. I honestly don't think the conversion is all that complicated. Price is a different discussion. You don't need the ECM to control the water pump or fans.
Old 06-07-2014 | 11:12 AM
user 8373900's Avatar
user 8373900
Originally Posted by FX4
Why does it not make sense? And by the same token on a 2014 water cooled bike you can just change the cylinder heads. Same motor, just different heads.
Actually the water cooled models have a little more compression, they all have different cams.
Mark
Quick Reply: Adding Liquid Cool to 2013 and older
