Adjustable pushrods, or remove rocker boxes?
Old 06-05-2014, 03:17 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
Go in thru the top, more time but pretty easy, you can typically re-use the o-rings for pushrod tubes if in good condition,
In the screamin eagle catalogue you will see list of cams and what size pushrod you can use, better to have dogbone torque adaptor to re-assemble, not sure if stubby ring spanners could also be used
Otherwise try and gauge torque from other bolts done properly
Thanks
Mirrmu
Old 06-05-2014, 03:27 PM
dawg's Avatar
dawg
dawg is offline
Received 3,230 Likes on 1,845 Posts
It helps with any twin cam, 88/96/103......etc. It is designed to allow for better oil return as opposed to going into the air cleaner. Rocker supports gotta come off anyway to take out and reinstall the pushrods and it only takes a few seconds to enlargen these holes with a bigger bit. To original poster, check the gerotor to make sure it stands proud per spec upon reinstall. Also a good idea to install a bypass shim or stiffer spring (Baisley or axtell setup) for better oil pressure. If you don't have all the proper tools, the oven/freezer trick works great on putting the new bearings on the cams (read through the pages here:http://harleyhog.host.sk/tensionerinstall.htm). Also do put in new lifters for insurance.
Old 06-06-2014, 10:29 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Originally Posted by evil451
cant help but subscribing because I too want to know...
I would think removing the rocker boxes is a big deal otherwise why would so many people opt for the adjustables to avoid taking them off right? interested on the responses.
not a big deal, simply a matter of preference. I've done plenty with stock pushrods and plenty with adjustables.
adjustable pushrods are $150 + per set, $190 if you go with SE. A rocker box cover gasket set is $14 and 15 minutes of your time to take the tank off and unscrew 12 bolts.
It all boils down to 2 things:
1. can you use stock pushrods with your new cam?
2. if so, do you want to spend the $ to buy adjustables or use what you have?
Old 06-06-2014, 11:26 AM
SummitRK's Avatar
SummitRK
SummitRK is offline
Well as i mentioned, due to uncertainty of health conditions, i don't want to invest a lot of $ now. If i do the cams, i'll probably just go with a cam that i can use that stock pushrods on. Also, now I am familiar with how the rocker box comes apart, and what's involved. (easy!). If all goes well, maybe i'll do the cams over the winter.
Old 09-29-2014, 03:04 PM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,548 Likes on 6,277 Posts
I am having my 88 base gasket leak fixed, and the SE Cam Tensioner upgrade. My estimate, from Sauk Prairie HD, includes replacement stock pushrods. Any reason to upgrade, or go to adjustables, when I plan to stay with stock cam, and not mess around after repairs?
My bike is a 2003FLHTCUI with 30k. I bought it with 2k in '11 and plan on keeping it, until death do us part.
Old 09-29-2014, 03:18 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
What about the inner cam bearings ?? Get rid the ina and replace with torringtons ??
Old 09-29-2014, 07:18 PM
Ron750's Avatar
Ron750
Ron750 is offline
Yes there are going to put in SE cam bearings. They only cost $30, so it's hard to believe they don't just use them in the first place.
Old 09-30-2014, 06:19 AM
UltraNutZ's Avatar
UltraNutZ
Top end is coming off anyways so with that said and stock cams, leave the stock pushrods in.
Old 09-30-2014, 07:09 AM
BoonDock_Saint's Avatar
BoonDock_Saint
BoonDock_Saint is offline
Originally Posted by SummitRK
Ok, first thing, the front rocker box leaks a little oil around the top. Bad gasket? not torqued properly?
When you pull the lid off, put it on a piece of glass (or a surface plate) and see if it's flat. If it rocks, replace it. it's never going to seal correctly if it's warped.
Old 09-30-2014, 09:57 PM
mike5511's Avatar
mike5511
mike5511 is offline
You can make your own dog-bone tool for torquing the rocker boxes back down.
I re-used the stock push rods when I swapped cams.
Attached Thumbnails Adjustable pushrods, or remove rocker boxes?-cam-swap-1-008.jpg
JeffJA
Engine Mechanical Topics
07-06-2018 02:23 PM
leachman
05-13-2018 06:50 AM
Ron C
12-27-2014 04:19 AM
texashillcountry
EVO
01-28-2014 09:00 PM
Stiggy
Exhaust System Topics
11
04-27-2013 08:50 AM
Quick Reply: Adjustable pushrods, or remove rocker boxes?
