Recommended 4 channel amp for FLHTCU
Old 06-04-2014 | 08:50 AM
equandt's Avatar
equandt
Default Recommended 4 channel amp for FLHTCU
I am looking at adding a 4 channel amp to my 2010 Ultra. I currently have the HD Boom speakers in it front and rear. Has any one added an aftermarket amp with the Boom speakers?
The HD Boom amp is not an option. Its too expensive and requires a dealer download to work. I'm not paying a dealer for any part of my stereo install.
I think my options are the RF PBR300x4, Arc KS125.5 Mini, J&M Performance 360W or the Hogtunes NCA40.4 amp. Anyone running these with the Boom speakers?
I'm looking pretty hard at the RF PBR300x4 but I've heard it has some heat issues. I'd like to know more about that.
Old 06-04-2014 | 09:08 AM
Pioneer74's Avatar
Pioneer74
You can't use the pbr300x4 with the Boom speakers. The speakers are 2 ohm and the amp isn't rated for anything under 4.
If you plan on keeping the Boom speakers, your best bet is the Hogtunes 40.4. The Boom's aren't rated for higher wattage car amps.
Old 06-04-2014 | 10:46 AM
DeadManWalkin's Avatar
DeadManWalkin
I'm running the Biketronics 4180 amp with Biketronics 7.1 speakers in the fairing and Polk MM 651 in the fairing lowers and it is loud! Biketronics amp is not too big either.
Old 06-04-2014 | 12:12 PM
The Q's Avatar
The Q
SoundStream 4.520D works great!!! You can also see what others are using by going to the Audio section of this forum.
Old 06-04-2014 | 12:32 PM
NascarGuy's Avatar
NascarGuy
+1 to the SoundStream 4.520D. Running MM651 6.5" speakers front and rear as well. Can't beat it for the price.
Old 06-04-2014 | 09:16 PM
equandt's Avatar
equandt
Thanks. I'll check out those amps.
Old 06-04-2014 | 09:20 PM
jjpish's Avatar
jjpish
I just installed the SoundStream 4.520D today. Running Kenwoood head unit and Alpine 6 1/2 in the fairing and the lowers. This thing just cranks!!! I did not expect it to be this good. Think I went partially deaf while I was fine tuning it...
Old 06-04-2015 | 03:04 PM
SDVmnt's Avatar
SDVmnt
Does the soundstream interfere with radio reception?
Old 06-04-2015 | 03:09 PM
austinslider's Avatar
austinslider
The SS is a class D amp, so it's hit or miss with FM reception. I don't have any issues with FM, but I don't listen to the radio that often. If you pick up a Soundstream amp, I would suggest picking up the 4.1000D. It's rated for 140w x 4 at 4 ohm. Way too much amp for your speakers, but could rock a set of BT 7.1's!!!!!
Old 06-04-2015 | 06:44 PM
0ldhippie's Avatar
0ldhippie
If ya are gonna try and keep those crap speakers ya don't need/want a lot of power. I think Alpine has a good small little amp and Kenwood just came out with one too. Just make sure they are good below 2 ohms.
http://www.sonicelectronix.com/item_...-KACM3004.html
cdavis7820
03-10-2018 06:23 PM
FrenchieM
Audio Systems
06-30-2017 01:20 PM
lowglidin
Audio Systems
12-26-2014 05:21 PM
Jagpanzer
Audio Systems
10-11-2014 09:30 AM
rome304
06-02-2013 09:42 PM
Quick Reply: Recommended 4 channel amp for FLHTCU
