Ignition switch
Old 06-03-2014 | 10:22 PM
scott01's Avatar
scott01
Default Ignition switch
I posted this in the mechanical section but got no response, so I'll ask here. I removed the ignition switch to do my ape install on my '10 SG and while replacing the riser bushings the forks locked. I thought no problem I've seen the guy on YouTube use a screwdriver to turn the switch one click clockwise and they unlocked. So that's what I did and then after the forks unlocked I returned the switch to its original location. So I thought. Well I got things back together enough to fire it up to check my wiring and when I connected the battery lead the radio came on. It should be off so I'm pretty certain I screwed up. I've got the top and bottom tumblers in what looks like the correct position but still having same problem. Can anyone tell me where I screwed up and how to fix it?
Old 06-04-2014 | 01:54 AM
mkguitar's Avatar
mkguitar
this happens all the time....screwdriver bad- it'll often turn some of the cams, but not all
the 1/4" squarshed copper tubing is much better because it doesn;t taper like a screwdriver.
all I can suggest is watch a couple more youtubes until you find one that addresses your problem
mike
Old 06-04-2014 | 05:44 AM
scott01's Avatar
scott01
Thanks Mike but I've searched YouTube for a detailed video on how to fix this problem with no luck. If anybody has a link or can offer a solution please post it. My bike is down until I can fix it. Been down going on 2 weeks due to my screw up lol
Old 06-04-2014 | 06:44 AM
harley7316's Avatar
harley7316
looks like you are in the on position both sets of tumblers have to be lined up. if you dont have a flat blade that goes through both sets of tumblers turn the bottom tumbler till it locks the forks then turn the middle tumbler untill its lined up with the bottom tumbler put lock back in and should be fine.Happened to me while changing fork oil
Old 06-04-2014 | 06:45 AM
iglideUC's Avatar
iglideUC
Old 06-04-2014 | 07:12 AM
scott01's Avatar
scott01
Thank you sir!! This is the knowledge I was looking for. All the video's I found showed how to remove and replace it but didn't explain what to do when things went wrong. Sounds easy enough and I'll be trying it when I get home
Old 06-04-2014 | 07:16 AM
scott01's Avatar
scott01
Thanks for the video. I'll be making one of those tools
Old 06-04-2014 | 08:29 AM
TWIN CAM 96's Avatar
TWIN CAM 96
If you don't have time to make the tool you can buy one for $25.00
Harley Ignition Switch Tool
Old 06-04-2014 | 09:02 AM
hooter57's Avatar
hooter57
I did the same thing when I changed out my forks, frustrated the hell out of me. I just kept at it with my screwdriver and eventualy got it. Next time I'm gonna make one of those tools!
Old 06-04-2014 | 09:39 PM
skydude426's Avatar
skydude426
Originally Posted by TWIN CAM 96
If you don't have time to make the tool you can buy one for $25.00 Harley Ignition Switch Tool
After reading this thread, I bought one of these. Worth every dime. Works very well.
Quick Reply: Ignition switch
