Antilock- synced breaks skid
I was doing around 60+ on a back road around a small curve when a car pulled out in from of me (Not too bad).
I thought since I have the linked breaks, I should be able to just hit the rear.
I thought wrong. My ars end locked up and swung around on me. I didn't keep it locked up too long of course to see if it would antilock would kick in but I thought it wasn't supposed to skid, especially just the back with linked system.
Oh well back to old school breaking...
No lights or codes showing. Is there any way to check them or troubleshoot with out going back out for a skid test?
It shouldn't skid, you're right. But using the rear brake only in a corner is begging to high-side.
'05Train,
It was more like a slight curve (enough to make it high side) but none the less your right. Thats why I was prepared for it and waiting to see if it would happen.
Right, Still shouldn't have skidded though
I'm not sure if I'm reading this right, but were you in the curve when you hit the brakes? Harley (and I'm sure all the rest) advise the ABS system only operates correctly when braking in a straight line.
We practice emergency braking in a curve all the time at work. The first step is to pop the bike upright just before applying maximum threshold braking. Two tires don't have enough traction to hold a curve and emergency brake at the same time. Motorcycle ABS does not work like a car's ABS which allows you to brake while turning.
ABS can't beat the laws of physics. If your rear tire broke traction in a curve for just a moment, the ABS system probably couldn't keep the tire rolling free enough to regain traction. You are lucky you didn't get high sided when you released the brake. Sounds like you were definitely in a tough spot.
As far as the linked aspect goes, I've played with mine quite a bit and you only get maximum braking force by applying both the front and rear. They are obviously linked together when applying either, but maximum braking requires both.
How does the braking system know if you are riding straight or going around a curve? Also, why in the heck would something like that be built into a bike?? I think your source is flawed.....
