anyone change their own tires
Old 06-01-2014, 08:51 AM
dochawken's Avatar
dochawken
dochawken is offline
Default anyone change their own tires
Using tire spoons? Was watching a video on youtube yesterday. I change my own dirt bike tires w/o an issue. Just wondering if there would be that much more difficult...rim protectors would be essential.
Old 06-01-2014, 08:56 AM
AlaskaAviator's Avatar
AlaskaAviator
AlaskaAviator is offline
Do it all the time. I don't use rim protectors. Don't know what they are actually.
Old 06-01-2014, 09:20 AM
btsom's Avatar
btsom
btsom is online now
Don't know about dirt bikes. The cast Harley wheels have a shouldered bead area making the bead pretty tough to break without a proper bead breaker. To remove and replace the tire you might need 3 or 4 spoons and an extra set of hands but it is doable. I use the Harbor freight tire machine with the motorcycle wheel attachment and lots of patience. Do you already have a wheel balancer of some type? If you find out you are in over your head, you can take your new tires and wheels (already off the bike) to a shop and have them finish the job ( a blow to one's pride). You probably already know how easy it is to bend a brake disk.
Old 06-01-2014, 09:25 AM
dochawken's Avatar
dochawken
never have damaged a brake rotor...two spoons should easily break the bead on a mc tire...I use ride gel to balance them...
Old 06-01-2014, 09:39 AM
rh8234's Avatar
rh8234
rh8234 is offline
Two spoons. No rim protectors. Cheapo bead breaker from J&P (or improvise with a large C-clamp and a couple pieces of wood). I have been changing tires on bikes since I was 16, and have NEVER balanced one and have never had a problem. (I did damage a rotor one time. Dropped a heavy object on it while the wheel was laying on the garage floor.)
Old 06-01-2014, 09:46 AM
rkoivisto's Avatar
rkoivisto
rkoivisto is offline
Default Tires
I bought an extra set of rims so I can change the tires at my leisure. Use a 2X4 and hinge mounted to a wall to break the bead.
I did have to take the last one in to get the tire changed. Runflat is a whole different animal
Old 06-01-2014, 09:54 AM
dochawken's Avatar
dochawken
I have a pit boss stand that I use for my dirt bike, I think it would work fine..
Old 06-01-2014, 10:00 AM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
I use a set of large wood clamps to break the beads. A set of spoons and 14 rim turned upside down.
Old 06-01-2014, 11:17 AM
skydude426's Avatar
skydude426
skydude426 is offline
I built this box out of 2x4's to set the wheel on. The rim sits on the wood and the brake rotor is inside the box. Then I use the scissor jack between the tire and the receiver hitch of our truck to brake the bead. Works like a charm. I then use the box to support the wheel on the floor as I use 3 spoons to get the tire off and on the wheel.
Old 06-01-2014, 12:30 PM
dochawken's Avatar
dochawken
Really like the scissor jack idea....smart!
Quick Reply: anyone change their own tires
