radio help!! works sometimes???
i have a 2006 streetglide and when i put the bike away last year the radio was fine. now when i turn the bike on sometimes the radio turns on some times it dosnt. It shows the cd is playing or that fm is on but no music. i have 12 volts exact when off and running i have 13 or 14.
More than likely you have a cracked circuit board inside the radio. This is caused on older bikes by two of the handlebar clamp bolts hitting the bottom of the radio. Harley has since started installing different bar clamp bolts. Might want to give Iron Cross audio a call. They fixed mine and did some other stuff to it. Works like a champ now.
If the radio is electrically functioning but you have no sound through the speakers, or it is intermittent you may have the dreaded speaker circuit board breakage issue.
Iron Cross audio has the fix at a price cheaper than finding a second hand radio. Just suck it up and they will make it better than new.
Oops just saw the post from the Q-- they fixed mine as well...
