Headlamp going out intermittenly
05-28-2014 | 07:02 AM
My headlamp doesn't stay on...bulb is good, fuse is good, I guess its the switch.
If I turn the brights on, when the lamp goes out, the bright light indicator goes out too.
Is the switch easy to replace?
05-28-2014 | 07:04 AM
Quote:
Originally Posted by
Gordon65
Check your ground first, then look for a bad connection on the 12V side.
05-28-2014 | 07:29 AM
nhrider1
ok...where is the ground? its an 09 ultra....thanks!
05-28-2014 | 07:59 AM
Could be the switch. But I'd be more inclined to suspect the wiring upstream of the switch.
05-28-2014 | 08:47 AM
Take the fairing off and look for rubbed or frayed wires, or loose wiring on the headlight connector.
05-28-2014 | 10:20 AM
I had this problem on a 2004,it was the head light 3 prong female connector.......
05-28-2014 | 10:29 AM
Definitely check the connector on the back of the headlight first for a loose wire, then hit the connector with contact cleaner and coat with dielectric before reconnecting. A little corrosion on the contacts can cause a lot of problems. Then check your grounds for looseness or corrosion. There's usually a ground connection on the neck somewhere.
05-28-2014 | 10:31 AM
I had a frayed wire in the headlight bucket that caused my high beam to shut off and on intermittently. I only noticed it when I was changing to my LED headlight.
sportster8681
03-30-2020 01:24 PM
BACADon
10-30-2015 04:47 PM
madsonp
10-26-2015 06:28 PM
SmittyFXDL
02-05-2015 09:08 PM
HDmikie
01-07-2012 07:20 PM
