Need help loosening jam nut on clutch adjuster screw
I tried to adjust my clutch yesterday during my primary oil change using the service manual instructions, but I couldn't loosen the jam nut on the clutch adjuster screw inside the primary. When I cranked on the nut to loosen, the clutch pack would turn. Bike was in neutral. Next I put the bike in 1st gear hoping that would hold the clutch pack in place, but when I cranked on the nut the bike started to move. I had plenty of slack in the clutch cable if that matters. This is first time for me doing it myself instead of dealer. 2012 RK, 103 stock engine w/Stage 1, 10000 miles.
Any ideas on how to loosen the jam nut? Or how to stop the clutch pack from moving when I try to loosen the jam nut?
Thanks!
Thanks!
Hold the brake while you loosen it or put it gear with something in front of the rear tire. I used my 3/8 electric impact to loosen mine, but tightened it by hand with a 17mm honda spark plug wrench that I have. Worked great because the socket has a hex on the end for a wrench. I know the nut is standard 11/16 socket if I remember correctly but that socket fit wicked good.
