High beam question
05-24-2014, 09:44 PM
High beam question
When I turn on my high beam I would like to keep the auxiliary lights on. Is there an easy fix for that?
Thanks in advance
05-24-2014, 09:49 PM
05-24-2014, 10:09 PM
Griffin,
Thanks for the quick response I will be picking one up my next time in.
Cheers
05-24-2014, 10:36 PM
05-25-2014, 10:20 AM
I just moved the "spot" wire from the low beam wire to the headlight wire in the harness. Cost; one butt connecter, some black tape and a couple wire ties.
05-25-2014, 10:29 AM
Quote:
Originally Posted by
GriffinDenim13FLHX
The harness kit will only work on 2013 and earlier models. The 2014 models are software defined: the dealer can flash the CPU to keep the aux lights on while on high beam.
They did this for me on my 2014 Trike. Charged me $26.
05-25-2014, 01:41 PM
Ahhh I see no problem. They went and changed the wiring on the 14's .
At least I said "might" help...
I assumed
it was the same.
05-25-2014, 01:52 PM
Check with the dealer for an 07...I have a 14 Ultra and I brought is to the dealer. They worked some magic and now it works like you want/
Just-Jeff
Thanks in advance
05-25-2014, 02:54 PM
Where is the Forum police?
05-25-2014, 03:17 PM
On my 2012 FLD I took my power for the aux lights from the parking light conection. I made up a splitter conection very easy.
Cheers John
Reason: missing info
