ME880 Tire pressures
Old 04-02-2007 | 07:23 PM
fishafly's Avatar
fishafly
Default RE: ME880 Tire pressures
ORIGINAL: 211Chuck
ORIGINAL: bluehwytn
Just installed a set on my 06 flhti after the dunlops went at 10,000 miles. Checked the metzeler site and was surprised to see the pressures listed at 38 psi for the front and 44 psi for the rear tire. I was wondering what other riders were putting in their tires since I thought this was a bit high.
Thanks,
Scott
That is the very bare minimum air pressure at 70
degrees F riding one up they are recommending.
42 PSI FRONT and50 PSI REAR is for two up loaded
at high speed and it is marked on your side walls!
38 PSI FRONT and 44 PSI REAR two up at high speed
in 80+ degree weather the tires will cup badly! Metzeler
won't mind that, but your wallet sure will
My sidewall says 42psi cold... ME880 150/70/18 Am I missin' somethin? Bought it from Hogpro...
leeroynakd
09-11-2015 05:21 PM
streetglidetroy
06-26-2013 12:27 PM
Brobrian
11-27-2012 10:08 PM
PoCoBob
09-18-2009 07:28 AM
OldBoldPilot
02-08-2008 12:29 PM
Quick Reply: ME880 Tire pressures
