help me pick between two cams
Old 05-23-2014 | 12:32 AM
Timothy Rau's Avatar
Timothy Rau
Default help me pick between two cams
2005 ultra currently with stage one pcv, dragos 2 into 1. I want to do a 97 or 98 big bore and have the heads done but cant afford it at this time. I am going to do the screamin eagle hydraulic upgrade with cams for now. My question is which cam will be better now and after big bore and head job and what is the difference between the two.I don't ride two up very often. wife isn't into riding.The two cams that are being recommended to me are the andrews 26 and andrews 37. Any insight on these two choices would be appreciated.
Old 05-23-2014 | 02:02 AM
Spanners39's Avatar
Spanners39
Personally I would use either the SE203 or 204. Both work well with the big bore but I find the 203 really good for Touring bikes as it has low down grunt and smooth delivery. HP/TQ numbers mean nothing, you need to tailor the cam to your needs.
97 and 98 big bores are snake oil. They are little more than the max oversize for the 95.
95 is fine for what you need and probably cheaper.
Old 05-23-2014 | 06:45 AM
glide2005's Avatar
glide2005
Don't rule out SS 510g cam's. I had the in my 98" 2005. The 510 cam are tq monsters, end up with 100hp and 112lb tq. I had the heads reworked, roller lifters, cam plate, and new SE clutch. And still got 40 mpg when ridden right, which is hard to do. The 510's make it thump like a dragster, but also make the exhaust a lot louder.
Old 05-23-2014 | 08:27 AM
Timothy Rau
Thanks for the imput, can anyone tell me about the andrews 26 and 37 ? Frank Dragos is doing the build and i trust him just wanting to hear what others think about these two cams.
Old 05-23-2014 | 08:33 AM
07RoadHawg's Avatar
07RoadHawg
I would go with the 37. You won't realize the full benefit until you do the bore and heads, but they would be better suited to the compression bump than the 26 after the work is done.
Bottom line, if Frank is doing your work listen to him. This thread will be a prime example of why you shouldn't take the internet's advice over your builder. You asked about 2 specific cams and the first two replies didn't mention your choices but recommended 3 others.
Old 05-23-2014 | 10:31 AM
fwb35's Avatar
fwb35
I would go with either the Andrews 37 or SE204, the S&S 510's are lazy below 3,000 rpm's
Old 05-23-2014 | 10:47 AM
0ldhippie's Avatar
0ldhippie
26 is a great bolt in for lighter 88s and will work very well in mild 95s. 37 is a much better choice for your planned 98 with headwork. I may even think of going bigger (54/57) depending on your build and riding style, since ya ride solo. Talk to your builder.
Old 05-23-2014 | 11:43 PM
ke5rbd's Avatar
ke5rbd
If he is doing the build and recommending them by all means go with the man. I would pick the SE204, then 203 then 37 then 26. Once you have the piston to valve clearance and springs for larger cams I would consider the S&S 551 or Andrews 57.
Old 05-23-2014 | 11:46 PM
ke5rbd's Avatar
ke5rbd
If he is doing the build and recommending them by all means go with the man. I would pick the SE204, then 203 then 37 then 26. Once you have the piston to valve clearance and springs for larger cams I would consider the S&S 551 or Andrews 57 or TW555.
Old 05-24-2014 | 01:15 AM
crimson13's Avatar
crimson13
Great Advice.
Quick Reply: help me pick between two cams
