Mounting the power vision?
Old 05-21-2014 | 08:32 PM
rage1187's Avatar
rage1187
Default Mounting the power vision?
Ok, im at a loss here. Does anyone have there power vision mounted on there handlebars on the 14 that would care to share a picture of? Ive taken off the brake handle assembly and tried that way = no go. if your not what the heck did you do with it while auto tuning?
Old 05-21-2014 | 09:35 PM
bkgabby's Avatar
bkgabby
I mounted mine but I think it's at a screwy *** angle and hard to see with the glare.
Attached Thumbnails Mounting the power vision?-tmp_imag0295965425473.jpg   Mounting the power vision?-tmp_imag0296-1136537104.jpg
Old 05-21-2014 | 10:09 PM
skratch's Avatar
skratch
when autotuning, i just put mine in the saddlebag. i have a small 'camera' case that it fits in perfect, fire it up and go.....
Old 05-21-2014 | 10:13 PM
scooterbum46's Avatar
scooterbum46
I thinned down the part of the mounting clamp that wraps around the bar (just ground the ribs off), loosened up the clutch master cylinder and slid the clamp under the body of it. It fit with the Master Cylinder clamped back down (was loose, not pinched by the MC). It is not on an ideal angle, but it's not that bad for now..
I use mine all the time to keep track of engine operating parameters - front and back head temp, ping instances, engine and intake air temp usually..
Old 05-21-2014 | 10:15 PM
spr0k3t's Avatar
spr0k3t
What's up with all the purple... reminds me of a really bad instagram filter. Got a better camera you can use? If you have a RAM mount, you could just throw it in there.
Old 05-21-2014 | 11:50 PM
ke5rbd's Avatar
ke5rbd
I used the Ram mount on 10 limited. Shouldn't be any different on 14 limited. Put it any angle you want. Haven't installed yet on 14 but will.
Old 05-22-2014 | 05:57 AM
Rdgray's Avatar
Rdgray
Here's what I use on my 13 but don't remember where I got it. Sits a little closer to me than I would like, but better than what came with it.
Old 05-22-2014 | 06:02 AM
circlenine's Avatar
circlenine
Late to the party, but the RAM X-Grip has worked for my Power Vision, phone, GPS, and even my camera when I tried it.
Old 05-22-2014 | 07:49 AM
gja's Avatar
gja
How has this worked for you so far? Looked at them but didn't feel real confident. the end of the X was right at the end of the PV from what I saw.
Old 05-22-2014 | 08:02 AM
Harley Hound57's Avatar
Harley Hound57
I have pretty much the same setup.
Quick Reply: Mounting the power vision?
