Mounting the power vision?
Old 05-26-2014 | 01:05 AM
SmokeyJoe101's Avatar
SmokeyJoe101
I like that idea, cheap and easy, if you already have the Garmin setup.
Old 05-30-2014 | 12:02 AM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Okay will try attaching the pics of my hybrid garmin /power vision mount. First pic post so hope this works!
Old 05-30-2014 | 12:05 AM
CalgaryBikeBum
Default Here's another view.
Sorry if pics bad
Old 05-30-2014 | 12:06 AM
CalgaryBikeBum
Default And one pic with it in place
Okay one of it on my bike
Old 06-08-2014 | 01:37 PM
mitchflhx's Avatar
mitchflhx
Default Power vision not reponding to touch screen
I just received my PV2. I installed all of the software, updated all software and firmware. Will installing the PV the screen got nicked. After connecting to the bike I was able to download a tune, and started setting up the gauges. I got part of the way through, and the touch screen stopped responding. I turn the bike off and back on, and the PV is still on the gauge setup screen. Any ideas?
Also does the on/off switch do anything? It does not respond to anything, short duration press, or a longer duration press......nothing. Thanks for any help.
Old 06-08-2014 | 02:24 PM
ke5rbd's Avatar
ke5rbd
It will default to the gauge screen once you put it on gauge screen which is normal. The being locked up is not normal. I think you have to push the little red button and hold it then turn the bike on to get it to reset. Not sure how long to hold it but probably several seconds. There is something posted somewhere on this. Have had one PV1 that the touch screen wouldn't work. Sent back and replaced it. You may have to do the same.
Old 06-08-2014 | 02:39 PM
sixguns's Avatar
sixguns
I have mine mounted right now, with the parts in the Fuel Moto bundle package. is that what you have? Did not have to remove anything off the bars.
ezridermn
EVO
06-14-2017 10:41 AM
albngore
02-26-2017 03:06 PM
wildone
05-19-2012 07:27 AM
patcham48
11-07-2011 11:18 AM
zoomie67
04-24-2007 08:48 AM
Quick Reply: Mounting the power vision?
