Upgrade from 96 to 103 on a 2008 Ultra Classic
Old 05-22-2014 | 07:36 PM
evil451's Avatar
evil451
If I have to change pistons I would rather go with a 106(SS) or 107(FM) proven kit...
Old 05-22-2014 | 08:19 PM
FX4's Avatar
FX4
Originally Posted by Punjabi HD
Harley 103" stage II has proven to be very reliable on our both 07 and 08 Ultra classics for last 100K miles combine better fuel mileage and adequate performance. For touring it's plenty of power to tackle any uphill or headwinds and that what was missing on stock 96". But you need ACR to reduce wear and tear on other equipment and an oil cooler will help with some heat issues. Try to negotiate for price though.
Yup this.
Old 05-22-2014 | 08:28 PM
bagman1's Avatar
bagman1
Originally Posted by bmaier
No longevity issues with 107 or 110 motors when built correctly. A good buddy of mine has well over 100k on his 110ci CVO SG.
So your buddies 110, that was a stock CVO motor I assume that got 100k? How many miles have you gotten on the 107 and what type of riding has it had?
Old 05-22-2014 | 09:29 PM
96inchBOB's Avatar
96inchBOB
Took my 96 to 103 for under $300 like $160 for stock harley 103 pistons and gaskets and $140 for bore with torque plates and hone. Labor I done my self like working on a Briggs very simple it is not worth $2 a hour to work on one of these out dated motors. On the 107 if you buy FM trick cylinders it will be great but a bored stock cylinder is mighty thin good way to get hot spots and out of round but to each his own. Come on guys these things are harleys nothing special the $20000.00 dollars plus is the name,shinny paint,and chrome and is as complicated as a Briggs&Stratton. Here is my Briggs hid by shinny black paint, wheels and chrome got a little tied up in this under engineered bike I call it my $15,000.00 BRIGGS.
Attached Thumbnails Upgrade from 96 to 103 on a 2008 Ultra Classic-image.jpg
Old 05-22-2014 | 09:41 PM
bmaier's Avatar
bmaier
Bagman, sorry, CVO had stage 1, aftermarket headpipes. no personal experience with a 107, another good friend has 60k on his 106 S&S motor on an 02 RK. I do have 79k great troublefree miles on my 09 stage 1 96, uses no oil between 5k oil changes. Best performance mod is downshifting!
Old 05-22-2014 | 10:40 PM
FX4's Avatar
FX4
CVO is stage III or IV from the factory just depending on the year and bike.
Old 05-26-2014 | 09:13 AM
turkeybird42's Avatar
turkeybird42
WOW, lots of diff opinion, LOL, looking for better power output ref climbing hills and long run, not a hot rod. Yes, stock all except for xeids. Well, have a great day.
Old 05-26-2014 | 09:18 AM
dawg's Avatar
dawg
IMO, unless you're doing crank work I wouldn't go with anything over a 103. If it were me, I'd do 103, cams and tune with a complimenting exhaust. On my 08 I currently have 96" with cams and gearing change and don't plan on a 103 until the engine needs refreshing.
Old 05-26-2014 | 10:32 AM
Bingee's Avatar
Bingee
Sound advice. Stressing the cases and crank shortens engine life. Even 103 can be a bit much depending on the cam. But you ride less than a few thousand miles a year, long engine life might not be an issue.
Jim Dawson's Avatar
Jim Dawson
I have 57,000 trouble free miles on my '08. I installed the 103"/SE255 kit at 8,000 miles and it does exactly what I want.
Quick Reply: Upgrade from 96 to 103 on a 2008 Ultra Classic
