Trouble with dresser duals..
I didn't have a problem with the DDs but the 4" Rineharts I put on them (specifically the right side) rides right up against the spindle nut in-spite of the divet on the pipe. Its my only dislike on the whole setup. Make sure they didn't short you any parts, mine was missing several parts, could that be a factor?
The pictures in the PDF that was copied sixteen times before going in the box are the worst, I downloaded the PDF hoping for better but no, the pics suck. Everything else about the install wasn't bad but figuring out the rear pipe bracket at the starter was maddening. Didn't help that I had removed and trashed the stock exhaust 3 months earlier. So going by memory wasn't an option. You pretty much need a picture and have to say those are the worst directions and pictures I've ever seen, and I've seen some bad Harley documents.
I'm thinking the pics were taken with a cell phone, printed and photo copied once or twice, scanned in and reduced to 160 bit, cropped and rotated twice, pasted into a PDF, and then saved at the lowest quality setting Adobe offers. Sound about right OP?
Did you remove the stock bracket? There was another bracket in the box for the dresser duals.
