Torque wrench on oil change
How many of you guys use the in-lbs torque wrench when you do oil changes?
The only in-lbs wrench (22"-lbs) I can find that will go that low in a click type is a Snap On and it is a good one but it costs like crazy. Cant really use a beam type, cant see it.
I never have used a torque in this application before, always just used a socket set. Just wondering if these drain plugs and threads are so much weaker than normal that they would require a exact torque.
CDI makes the snap on. I've got this one. Looks great but isn't any more accurate than my harbour frieght wrench....big difference in appearance and finish though.
To the OP;
I don't use a torque wrench on a oil change, or on very many other things either.
