Duals without re-map?
RE: Duals without re-map?
I've installed the fullsac dual conversion along with a set of recored Road King Mufflers. I was told by my dealer that I didn't need the remap till I replace the filter with a K&N or a Screaming Eagle filter. He mentioned to check the plugs after a day and so far no problems. I just had my 10k service done on my 06 flhti and had the injectors replaced with the 25 degree ones since I was getting coughing in between gear changes at times. Now the bike runs perfect but I'm probably going with a K&N soon and possibly some louder slip ons like bassanis or some supertrapp internal disc slip ons. I'd check the plugs after a day or so and see exactly what color they are. Hope this helps.
Scott
Scott
Hi, I did a set of rush slip ons with 2.5" baffles and no other changes. While i get alot of pop on decel and major drag when off throttle, the bike runs ok. I AM getting some blueing tho on the right side muffler. So I know I am waaaay leaned out. I will be doing the sert I think with a k&n as soon as i can. I qwant to open this beast up and see what she can do.
ORIGINAL: a.boogeyman
Yer going to need a Race Tuner etc or other device and ideally a dyno to get the most out of your bike. I just installed the same setup yesterday and it's at the dealer for a dyno now.
