Anyone use a rear tire on the front?
Old 05-16-2014 | 02:07 PM
grbrown's Avatar
grbrown
Originally Posted by Joe12RK
Some tires say front or rear fitment only, some don't. It all depends on the way that particular model of tire was manufactured. Old time belted tires didn't care what end they were mounted on. Many newer ones are more specialized. Again, you don't know without reading the sidewall.
There was an era when bike tyres were marketed for both applications and said so, with direction arrows for both wheels. However that is a long time ago! Personally I wouldn't swap tyres, not least because I don't have odd tyres lying around looking for a home! Another reason for not using a narrow rear tyre on the front is load rating, as narrower tyres often have a low rating.
As for running a 150/80 with a narrow belt, you should have plenty of room. I've used one in my bike with an '07 s/a and wheel and been able to fit the stock belt guard.
Old 05-16-2014 | 04:10 PM
btsom's Avatar
btsom
For those who have tried a rear tire on the front and reversed the rotation: Why? I understand that the main job of the front tire is braking BUT my understanding of the tread pattern direction is for water flow. Spinning the tire in the designed direction should flow water away from the contact patch more efficiently than running it in the opposite direction, or is there something else to consider?
Old 05-16-2014 | 04:16 PM
Joe12RK's Avatar
Joe12RK
Amazon Amazon
Front or rear fitment
Old 05-16-2014 | 04:42 PM
Jeepman1991's Avatar
Jeepman1991
Originally Posted by Thickraybans
I've been using rear tires on the front of my bikes off and on for 30+ years without an issue. I mount them with the directional arrow reversed. My King has a Shinko 881 160/60 16 on the back, and a Shinko 777 140/90 16 Rear tire on the front. Handles like a dream.
Care to share why Sir??? Very curious!!!
Old 05-16-2014 | 04:44 PM
Von_Zipper's Avatar
Von_Zipper
I tried it once and my bike started to go backwards.
Old 05-16-2014 | 05:04 PM
Thickraybans's Avatar
Thickraybans
A rear MC tire is built to react best to acceleration forces. A front MC tire is built to better handle braking forces. So if you are installing a rear tire on the front reverse the rotation.
Most modern MC tires are built with a randomized tread pattern to cut down on noise and rpm induced vibrations. A lot of older tires have a symmetric tread pattern, and have the same foot print both directions. Not to many with a directional tread pattern.
I wouldn't run a tire with a directional tread pattern reversed on my bike.
Old 05-16-2014 | 05:08 PM
Thickraybans
Mostly because the size I want for the front is only made in a rear fitment.
Old 05-16-2014 | 05:10 PM
btsom's Avatar
btsom
Thanks.
ARBOC
2014-2023 Touring Models
06-22-2017 04:16 PM
fourburgs
06-30-2012 11:27 AM
rns99
05-22-2009 12:18 AM
edie tweetie
10-06-2008 09:36 AM
Nighttrain07
06-24-2008 06:51 PM
Quick Reply: Anyone use a rear tire on the front?
