coat hanger trick??
Old 05-15-2014 | 09:15 PM
steelerdude1's Avatar
steelerdude1
String and a vacuum cleaner with a 1" attachment. Sucks the string right through. Attach to the wires and gently pull them through. Easiest way I have found.
Old 05-16-2014 | 03:21 AM
Strudy68's Avatar
Strudy68
Originally Posted by cdestuck
Or take fishing line and tie a piece of plastic to it. A piece from a shopping bag is fine. A size that would easily go through the bars. Use your shop vac on the other side to suck it through
this works good!!
Old 05-16-2014 | 05:28 AM
TN Houndog's Avatar
TN Houndog
The best thing I've ever found to pull wires through handlebars or any other kind of conduit enclosure is speedometer chain. It's flexible yet stiff enough to be pushed through whatever you are threading wires through easily. I've been using it for this purpose over 40 years.
Old 05-16-2014 | 06:14 AM
PFWiz's Avatar
PFWiz
Originally Posted by Justin Kelly
Small chain from hardware store..Easiest I have found.
Yep,
I used a ceiling fan pull chain that I bought at Lowes for $2. Heavy and flexible enough to fall right through the bars and strong enough to be able to tug on it pretty good....
Old 05-16-2014 | 07:13 AM
Briboysr's Avatar
Briboysr
The last time I did this I used a 24" Wire Tie.
It was plenty stiff but easily bendable. Worked great.
collin's Avatar
collin
String trimmer line, flexible and stiff.
Old 05-16-2014 | 07:16 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Tie a small nut to the end of fishing line or string and then no suck or blow is required.
Old 05-16-2014 | 07:20 AM
elPrez's Avatar
elPrez
Originally Posted by MNPGRider
So, here we are at the age old question. Is a suck better than a blow?
Either one HAS to be better than using a coat hanger...unless the person is into that kinda thing.
Old 05-16-2014 | 07:35 AM
Raddazzz's Avatar
Raddazzz
I messed around with mechanics wire for about 20 mins , then tried twine with a small ball of tape on the end. Hooked up shop vac to the end of bars and pulled it thru in seconds.
Old 05-16-2014 | 07:49 AM
Joe12RK's Avatar
Joe12RK
Quick Reply: coat hanger trick??
