Roadking lowering questions
I have a set of Street Glide air shocks if your interested.
I also did it, and also went back. I'm also short legged, so you'd think I would have stayed with the shorter shocks.
With oil tuning, I was able to get both of them nice riding. But the 13" shocks are nicer than the 12" shocks. 12" shocks have a stiffer spring, so even with oil tuning, they are just a bit harsher. Or more accurately, I was able to get the 13" shocks sweeter than I could the 12" shocks.
The bit of seat lowering I got with the 12" shocks wasn't worth the ride degradation, the reduced ground clearance and the reduced lean in turns.
so there's your 2 easy low(er) cost options.
on my FLHTC I ran SG shocks the past couple of years and it was "ok". not great but ok, harsher ride as the damping has to happen in 2/3's the suspension travel in 2/3 the time.
and I still went back to 13" when touring.
on a whim I bought the $16 + 9 shipping ebay lowering blocks from a forum member and threw them on the other day with the 13"
the ride is much smoother than with the FLHX shocks.
these do alter the angle of the shock which won't work with the RK Classic bags
This change will reduce my conversion time from "city" to touring ride heights as I'll only have to swap the lower shock mounting point.
so far, so good- $25.
mike
mike
I ride with friends that have Glides and RK Classics only about a half inch difference in seat height between them. I prefer the very slightly firmer Glide, better road feel and handling. More than makes up for a very tiny loss of lean angle. IMO For $125 bucks pick up a set, if you don't like em re-sell them. Also just my opinion the stock air shocks on both bikes suck.
