Piston Came Out of Caliper During Service. Replace or Repair Caliper?
2011 Street Glide, w/ABS.
Got a little carried away while cleaning the pistons on my front brake calipers with a shoelace & brake cleaner, and one of the pistons popped out of the bore of the caliper.
I gently pressed the piston back in the bore and cleaned up the brake fluid mess.
Am I good to go after a thorough bleeding, or should I take this opportunity and replace the compromised caliper?
Thanks
Thanks
I didn't see, or look for, the seal. I just popped the piston back on the bore.
Should I now disassemble the caliper, or am I good?
I hate to have this caliper leak fluid all over the new Lyndall pads I'm about to install.
Thanks
Thanks
